crank mount front hydraulic pump on 420w
76boler
04-16-2007 16:46:46
How would one mount a front crank driven hydraulic pump on a 420w? Is it possible? Thanks Jim
Hayfarmer
04-17-2007 07:14:04
 Re: crank mount front hydraulic pump on 420w in reply to 76boler, 04-16-2007 16:46:46
I had a hub bolted to the crankshaft pulley on my 430 that would accept a shaft to run a front hydraulic pump. Always thought of running a power steering pump off of it. I think it also has the place for a hand crank but the hub bolted over it in some holes already in the crank pulley. Have seen lots of them around so must not be a problem.
76boler
04-17-2007 08:41:51
 Re: crank mount front hydraulic pump on 420w in reply to Hayfarmer, 04-17-2007 07:14:04
thanks will look a little harder
02
04-16-2007 18:44:26
Got one on my 420U. bolted to a bracket which in turn is bolted to the front of the tractor.stinger shaft fits in crank pulley.
76boler
04-17-2007 03:51:09
 Re: crank mount front hydraulic pump on 420w in reply to 02, 04-16-2007 18:44:26
my problem seems to be that the hole where the handcrank fits into the crankshaft pulley has a cast set of ears to engage the handcrank and not any place to bolt a flange to run a stinger shaft, any suggestions Thanks
jCarroll
04-18-2007 21:00:09
 Re: crank mount front hydraulic pump on 420w in reply to 76boler, 04-17-2007 03:51:09
I think you will find 4 holes through the crankshaft pulley which let you bolt a hub which has splines to drive a hydraulic pump.
Look at the Parts Book for a 420C with 92 loader.
