4020 gas electronic ignition
toolz
04-15-2007 23:24:57
Is there a kit, or an easy way to install electronic ignition in my '65 4020? From my experience with old cars, I'm sick of points. Thanks for your help. toolz
toolz
04-16-2007 22:55:41
 Re: 4020 gas electronic ignition in reply to toolz, 04-15-2007 23:24:57
Thanks for all the advice. This is something that I will probably try. Who makes a good kit?
fxstc87
04-18-2007 07:44:21
 Re: 4020 gas electronic ignition in reply to toolz, 04-16-2007 22:55:41
I installed the Pertronix conversion kit in my 50 and am extremely happy with the results. If you are concerned about it failing, keep the points and condenser in the tool box. You can switch back in just a few minutes.
machinery-man
04-16-2007 08:22:34
With any post there can be situations where a person can"t say enough good about a situation or enough bad. Personally I prefer the electronic or breakerless system due to the higher output and cleaner firing of the lower quality fuel that is on the market. While points might be sound I had no trouble with 6 installations. You have to install properly just as you do points but found little or no maintenance required. I had trouble finding good quality points through John Deere or wherever and atmospheric(moisture) seemed to be a real culprip with corrosion. Personally I would recommend trying both and then compare the difference. I have had 20 club member poopoo the electronic but had never tried it.
jdemaris
04-16-2007 08:44:17
 Re: 4020 gas electronic ignition in reply to machinery-man, 04-16-2007 08:22:34
My comments aren't focused on reliability. Anything can fail - regardless of who makes the components. But - you can take a breaker igntion made 100 years ago - and still find parts for it pretty easy. With electronic conversions - many companies have come and gone in the past 40 years. For many, there ARE no replacement parts. That even applies to some big companies and OEM parts. And, with a modern conversion system - if something does fail - I doubt there are going to be any parts available locally - unless there happens to be a parts-stocking dealer nearby. It's a matter if the advantages outweigh the disadvantages - and some of that is based on personal choice. I like owning something that I know I can quickly and cheaply repair. And, one of the things I like about older tractors is their simplicity, ease of repair, and generic parts availability.
jdemaris
04-16-2007 05:47:53
There's a down-side to having those kits. You ever get stuck because it fails - you're not going to find parts locally - to get it going again. Whereas if you retain the original setup, there is - under normal conditions - nothing that can fail that you can't find parts for, and fix - quickly. I've have converted several - cars and tractors - back to original for that reason.
Mike M
04-16-2007 06:32:41
 Re: 4020 gas electronic ignition in reply to jdemaris, 04-16-2007 05:47:53
Gee finally someone else who still runs points !!! Nothing like being able to clean,file,or swap some out from an old junk car/tractor to save the day. But this isn't even that often if you go over them good right after you buy one and before you put it into service.
jdemaris
04-16-2007 06:51:35
 Re: 4020 gas electronic ignition in reply to Mike M, 04-16-2007 06:32:41
I had a bad experience a few years ago. Somebody gave me a fully "restored" 1969 MGB - but it was 300 miles away. I attempted to drive it home - and about half-way - on the Interstate - it died. Popped the hood ( or at the Brits say - the bonnet) - and found no spark and also discovered the ignition had been "improved" with an electronic breakerless conversion. It was dead - and I considered myself screwed. But . . . also had a bunch of boxed parts that came with the deal - and to my surprise - one had all the orig. ign. parts in it - dirty old breaker-plate with points, etc. In about an hour I had it back to original and drove it th rest of the way home. If I hadn't had the orig. parts - I never would of found repair parts to fix the conversion-kit and it would of gotten towed. I've had very little trouble with points - they are pretty reliable. Yeah, had several times after a tractor sat for months - that I had to pop the cap off and scrape the points with my jackknife. I can live with that.
Mike M
04-16-2007 04:37:59
There is suspose to be kits for about everything. I do see alot of posts about trouble with the electronics too. I suspect most of it is related to improper installation and not solving the REAL problems and trying to use them for a cure all. If set up right points will run for years trouble free. I put a new set in our 4020 back around 1993 and they are still fine but only have put around 700 hrs. on it.
