JD 400 backhoe
scooter01922
04-15-2007 20:31:56
First off i would like to thank all of you for your help so far. Just for starters i now know that the tractor is a 400 and not a 500 backhoe and have managed to find a new block for it. Now for the question...i have also located a running "JD 4039" 4 cyl industrial diesel that looks really,really close to what i need to repower the tractor. I sent the guy a message regarding the block #. My block # is T26933.
I looked through the JD parts site and can"t seem to reference the two to anything common. But it LOOKS so damn close. Any thoughts on what it might take to plop this engine in.
Thanks
Scott
jdemaris
04-16-2007 06:10:57
 Re: JD 400 backhoe in reply to scooter01922, 04-15-2007 20:31:56
I wouldn't use that engine without some specific specs. Deere made several 239 (4039D) versions that have lightweight blocks that are not built strong enough to be an integral part of a tractor.
Your 2020 ag. or 400 indust. tractor uses the engine block as part of the weight-bearing part of the tractor and has the front-axle bolted to it. For that reason, the original block is cast extra heavy. And, some of them still crack blocks where the front-axle assembly bolts to it. Many of the 239s are made to be power-unit engines only - or - put into tractors that have a lot of additional side-frame support. Also - Deere made versions of that engine with all the balancers left out of it - as a cut-cutting feature. We had a lot of vibration troubles with them. When the Deere 210 backhoe first came out - Deere put the cheaper 4039s into them - and they tended to cracked exhaust pipes and mufflers and had assorted bolts come loose, here and there, from the engine vibration. Don't assume just because the engine might bolt-in, that it is automatically suited. Check weight-bearing specs. carefully. There are many heavy-built engines around to fit that tractor - 202s and 219s - both pretty common in 450 dozers, 2020 tractors, and more. I remember when the 239 first came out - Deere warned us about not mixing light and heavy blocks for certain applications - but I don't remember all the details.
720 in pa
04-16-2007 03:28:19
wont take anything just put it in all mounting bolt holes are the same actually yhe block itself is the same only a bigger bore for the sleeves.one thing to check is the lenght of the crank . measure from timing cover to end of crank on both engines and see if it is differentsome 4039s had a longer nose on the crank
scooter01922
04-16-2007 10:03:31
 Re: JD 400 backhoe in reply to 720 in pa, 04-16-2007 03:28:19
Thanks guys...thats why i come here you know it all. I will have to do some more checking now that i have the casting #. actually the guy sent 2 casting #'s ????? R116194 and R116195 ??? I would love to check the length of the crank but as the engine isn't out of the tractor yet i have no reference to go by and the potential replacement isn't local. Thanks for the info
Scott
scooter01922
04-16-2007 13:25:12
 Re: JD 400 backhoe in reply to scooter01922, 04-16-2007 10:03:31
Ok i just got off the phone with a dealership who was able to tell me that this particular engine has balancer shafts but couldn't find out about the light or heavy block thing. Engine model # is actually 4039 DF. Any further thoughts???
Thanks
Scott
