4430 trans pump
paulsdiesel
04-15-2007 19:09:17
hello all-been working on this tractor for low pressure in trans pump circuit;and pretty sure it is bad leakage @ pump area.my question is can rockshaft cover be removed/installed without removing cab? i read somewhere about it being done on another series using a fixture bolted to back of housing. this cab has this gosh-awful brush cover welded all over it--trying to keep from cutting-rewelding. thanks for any help
G/MAN
04-16-2007 17:51:46
 Re: 4430 trans pump in reply to paulsdiesel, 04-15-2007 19:09:17
Rockshaft housing can be removed with the SGB installed, but it's not easy or a one-man job. The fixture bolts on the end of the rockshaft cylinder after the end cover is removed. Usually it's square tubing bolted to a plate drilled with the correct holes to mount up. A few feet back from the plate you weld on some sort of eye to attach a hoist to, and then normally you'll want an additional "cheater pipe" up to 10 feet long or so to slide over the welded-on pipe so you can counter-balance the rockshaft housing while it's hanging from the hoist, and that housing is HEAVY. Also make sure the bracket that supports the SCV linkage is unbolted from the rockshaft housing, and you'll need to raise the rear of the cab some - make sure you don't tweak anything else - shift linkages, etc. And there's a really nasty bolt located right dead center in the front of the housing, or at least I believe there is - a real treat to get to. Are you absolutely sure your leak is at the tranny pump? Major leaks at the tranny pump aren't terribly common. I'd suspect a leak at the rockshaft valve before anything else. Remove the adjustment hole plug from the rear of the differential housing and look in underneath the rockshaft valve with the tractor running and the oil at operating temp. Some oil running down is fairly normal. A waterfall of oil squirting out all over is not, and the rockshaft valve will need rebuilt, which can be done by simply removing the valve itself, not the entire rockshaft housing. Another potential leak point in that area is the steel plate that covers the bottom of the rockshaft housing - I've seen them crack and break. If that's the case, the rockshaft housing will need to be removed.
paulsdiesel
04-16-2007 23:12:25
 Re: 4430 trans pump in reply to G/MAN, 04-16-2007 17:51:46
thank you for reply. ok; heres what this 4430 is doing--quad shift functions ok,brakes,i think--no steering or lift/remotes til you rev engine to 1900-2100 rpm. checked fluid flow @ filter housing;bucket/stopwatch method-seems 12gpm;suction filter&element ok-as relief valve housing.gauge @ test ports show 115psi @ 800rpm-[clutch;pto on/off all same] no fluid to main pump til engine speeded up; pressure comes up also.now, the reason i was going to pump was because i thought when i idled tractor & 3-point was not getting any fluid from front pump; that waterfall i see is coming from trans pump-i was going to get fittings to dead-head pump[carefully] but kinda convinced myself that i needed to go under the cover. will 3-point valve assy or bottom plate have fluid when they don't work? i will verify output from pump & chk for leakage downstream if pressure is available.well;thanks for any help.
G/MAN
04-17-2007 16:46:37
 Re: 4430 trans pump in reply to paulsdiesel, 04-16-2007 23:12:25
I think you've got a problem elsewhere in the system - possibly in the steering circuit or priority valve. Steering is a priority function - it and brakes should get oil first and foremost before anything else does - being able to stop before hitting something or steer around it takes precedence for safety reasons. The proper operation of the two-speed in the QR really doesn't factor in to your diagnosis - the Perma-clutch and two-speed function off of low-pressure transmission system pressure oil, not the 2000+ psi oil the main hydraulic system has access to. You could actually be dealing with several different problems here. If your 115 psi is "system pressure" for the trans, that's pretty low for a 4430, but then again I believe that system pressure is supposed to be checked at 2000 engine - it's bound to be quite a bit lower at 800. I'd really suggest getting a hold of a manual and do the step-by-step diagnosis. That really is the best way to quickly and accurately identify the problem(s).
paulsdiesel
04-17-2007 19:59:10
 Re: 4430 trans pump pulled rockshaft cover tonight in reply to G/MAN, 04-17-2007 16:46:37
hi G/MAN; did more checks today-pulled valve assy first-and yes there is spray at trans pump--rigged up & pulled cover--and found retainer plate that holds pressure pipe into pump broken; pipe kicked out--i pushed pipe back in & it doesn't go up square--may even be cracked-yeah; you are right about this tractor having more than one problem--before i saw it, several things messed with & main pump rebuilt-also i have better manual coming--you said this problem not common-i have not gone to pressure reg yet because i didn't have enought-but you can bet i will- stuck valve or shimmed too much cause this? sure was a deep mark where retainer had vibrated in wall of tube.-maybe vibe broke it. will try to remove tube tomorrow-do you remove pump & reg assy to do this? thanks for everything
G/MAN
04-18-2007 17:55:44
 Re: 4430 trans pump pulled rockshaft cover tonight in reply to paulsdiesel, 04-17-2007 19:59:10
I'd definitely recommend pulling the transmission pump, if for no other reason than now's the best time to disassemble and inspect it. If could be worn out in addition to the leakage issue you've found, and now's the time to replace it if it is. Too much work to go in there again later, and if the tranny pump isn't up to snuf, the whole system takes it in the shorts, performance-wise. When it's all fixed up and back together, I'd recommend doing the basic hydraulic pressure checks. Heat the oil up good with a jumper-hose installed in an SCV box at high flow to circulate oil, and then check your transmission system, transmission lube and hydraulic system standby pressures. The sytem pressure and lube pressure ports are located on the clutch valve on the LH side of the clutch housing, and the standy pressure port is located on the pressure control vavle on the RH side of the clutch housing where the pressure line comes back from the main pump - your manual will show you all this, and how to adjust the trans system and standby pressures if they're out of spec. There's no adjusting lube pressure to speak of - it pretty much is what it is, but as long as there are no major issues in the two-speed or Perma-clutch oil circuits and the tranny pressure is good, you should find the lube pressure to be well within specs.
G/MAN - I should add...
04-18-2007 17:57:49
 Re: 4430 trans pump pulled rockshaft cover tonight in reply to G/MAN, 04-18-2007 17:55:44
You'll also see this in the manual, but watch out for the shims that will be behind the tranny pump. They set the bearing preload and endplay of the top shaft in the transmission, and you won't want that getting out of whack. Also take a good look at the trans pump drive shaft where it drives the pump gear. If it's rounded off at all, replace it.
G/MAN - wrong answer...
04-18-2007 18:00:05
 Re: 4430 trans pump pulled rockshaft cover tonight in reply to G/MAN - I should add..., 04-18-2007 17:57:49
Don't worry about the shims. I forgot that they're on the front bearing retainer in a Quad-Range. I was thinking of the reduction gear shaft in a powershift tranny - I don't wrench on many QRs.
Tx Jim
04-16-2007 04:08:44
It's been many years since I R&R rockshaft housing from a 4430 but it can be done without removing SGB. I think I loosened rear mounts and jacked rear of SGB up for some extra room. Be sure when on reinstallion you get the L&D in right place on rockshaft Have you checked the trans pump drive shaft for wear??? I had a rockshaft housing crack/blow-up while operating valve inside SGB onetime and that will make skid marks in your undies!!!!! Tx Jim
paulsdiesel
04-17-2007 20:34:10
 Re: 4430 trans pump in reply to Tx Jim, 04-16-2007 04:08:44
hi tx jim--yes rockshaft cover is off i couldn't get cab jacked up very much because of brush guard welded & braced all over this thing-[don't know will service a/c-not me] i pulled valve body first, than removed the rockshaft follower link--gave me a clean shot off studs, than back-not familar with this operation; so i'm going slow-asking questions-am getting real manual fri. sure value everyones advice & finding good info in archives also, paulsdiesel
