2440 Power Steering Failure
Carl R. Ernst
04-15-2007 18:00:16
I have a late model 2440 with power steering problems. When temperatures fall below 20 degrees I cannot turn the steering to the left. After the tractor warms up (30 minutes or more depending on how cold it is) the problem goes away and the steering turns freely. I have cleaned the filter screen and have replaced the hydraulic fluid. This did not help. I suspect a valve in the power assist column unit is failing and the entire valve assembly needs to be rebuilt. If anyone has experience with this problem, I would appreciate hearing from you.
