70 Power Steering Questions
MDM
04-15-2007 14:38:38
I just got a 70 gas home and was trying to figure out why the power steering locks up when filled with oil, it was dry when I bought it and the steering worked fine(manually), when I filled it, and started the tractor, the steering locks up and will not steer at all, The seals are leaking badly, but I wanted to check it out before I removed the pump to rebuild it. this is my first 2 cylinder with power steering, any thoughts on what might be going on?
Glen in TX
04-15-2007 21:44:41
 Re: 70 Power Steering Questions in reply to MDM, 04-15-2007 14:38:38
Not much telling if it's been run without oil what all can be messed up or worn out. You'll need at least a I&T manual and better yet as metioned the SM2050 power steering JD service manual. Probably be a good idea to flush it a few times no matter what oil you filled it with and then yes go back with the JD power steering oil. There are steering box parts that wear and actuator sleeve and adjustments to pressure too and a manual will help you thru all that and trouble shooting. JD manuals 800-522-7448 or Ed 812-537-4622. Post back later what you find or other problems and go back and search archives here too as FIT has posted lots on the power steering woes and fixes.
Larry806
04-15-2007 19:07:03
Number one question ? what did you fill it with??
If you used anything except John Deer Power steering Fluid you may have caused yourself a lot of problems .
Mike M
04-15-2007 16:17:43
John Deere should still sell the service manual SM2050 on just those power steering units. This is a MUST HAVE if your going to work on one of these.
Common for them to leak and also bind up from wear. There are several adjustments to that unit that may help.
