JD 1020 having trouble, Need info please
Farmer(Ga)
04-14-2007 19:28:22
Neightbor lady bought the JD 1020 i was asking info about earlier this week, She said it crank and ran good, she bought a plow and was plowing her yard,stoped for a water break then it would not crank up,waited about 30 min and it did crank up but in about 30 min it quit just like cutting switch off, Does this sound like an elect. problem? any input will be appreciated. James
MLD
04-17-2007 08:31:18
 Re: JD 1020 having trouble, Need info please in reply to Farmer(Ga), 04-14-2007 19:28:22
Sence it starts & runs fine when its cold & stops after it gets hot. I would think its the coil?
rrlund
04-15-2007 12:25:21
Does that still have the original electric controlled needle valve on the bottom of the carb? That thing shuts off the gas when you turn off the key. Mine went bad several years ago and I replaced it with a standard manual needle from the dealer. Problem solved.
Handsome Jim
04-15-2007 06:23:49
We had one that did the same thing. When I made inquiries I got suggestions that it could be fuel, coil, or condensor, I changed the coil because that was something I could do myself. That seemed to do the trick.
LorenNC
04-15-2007 03:00:46
Sounds like a plugged fuel line. My 1010 has a microfilter inside the carb where the fuel line connects.It was completely blocked with crud. Might want to check that out.
