JD 1010 starting
Neal D.
04-14-2007 15:30:53
My 1010 has gotten to where it will only crank after you turn the key back from the starter position to the run position. As long as the starter is turning it will not fire, but as soon as I turn the key back from the starter position, to on position, it fires up. Hope I explained this ok. Anyone with ideas on why it does this?
jdemaris
04-15-2007 07:42:30
 Re: JD 1010 starting in reply to Neal D., 04-14-2007 15:30:53
You've got to figure out how it is now wired. When the 1010 was new - Deere used a special ignition switch that had the IGN resistor and bypsass all built into the switch. A bad switch can give you the type of problem you describe. Later - late 70s - Deere came out with an update kit with a different switch and a separate IGN resistor. If you have a Delco starter - you can just use a standard IGN switch and use the "R" terminal on the starter-solenoid for bypass. It makes things easy.
