4620 oil in water
HJ
04-14-2007 08:45:11
Just got a 4620 in the shop that has a problem.
After running for short time it starts pushing water out of the radiator overflow. There are also some traces of oil in the water. What the chance it is a cracked head or bad head gasket versus bad o-rings on the sleeves?
Tx Jim
04-15-2007 04:22:27
 Re: 4620 oil in water in reply to HJ, 04-14-2007 08:45:11
If radiator cap holds rated pressure I think a new head gasket and head check is needed. Tx Jim
msb
04-14-2007 08:54:16
Probably the oil cooler or cooler gaskets. A lot easier and cheaper to check out first than pulling the head. Bad liner o-rings are not the problem, If they were you would be getting coolant in the oil.
