8640 hydraulic flow
Attila
04-14-2007 07:54:42
My 8640 seems to have lost 50% of the hydraulic flow to the remote connections. It seems slow now in raising any implement or operating my air seeder. Would the pump have gone on me or would a valve be stuck open somewhere reducing the flow to the remote cylinder connections. Any help would be appreciated.
Bob
04-15-2007 00:33:01
 Re: 8640 hydraulic flow in reply to Attila, 04-14-2007 07:54:42
1.) Have you changed the hydraulic filters, and was there anything in them (clutch or brake material or metal filings)?
2.) Is there any abnormal heating of the hydraulic system? A "high pressure leak" that keeps the pump "in stroke" all the time will make the system run hotter than usual.
3.) If neither of the above apply, it's going to take a little detective work with a flow meter test set and a factory service manual to be SURE if the problem is the main ( front pump), or some other obscure problem with the hydraulic system.
attila
04-15-2007 12:06:19
 Re: 8640 hydraulic flow in reply to Bob, 04-15-2007 00:33:01
Yes Bob: I did replace the hydraulic filters and there was no metal filings or material visible. There has been no abnormal heating of the hydraulic system. When I first noticed the reduced flow was when I was seeding. The hydraulics were working good then when raising the drill the fan speed (hydraulic) reduced sharply. The following morning I did replace the filters but this did not solve the problem.
G/MAN
04-16-2007 18:05:31
 Re: 8640 hydraulic flow in reply to attila, 04-15-2007 12:06:19
Right off the top of my head I'd suspect a problem in the stroke-control valve area of the pump control valve block mounted on the front of the pump. The spools and valves in that block are the items that allow the pump to go into and out of "stroke" in order to maintain proper system pressure at all times, regardless of the amount of oil required. The problem either lies there or there is some sort of internal leak somewhere preventing the main pump from getting all the oil it should be getting from the transmission pump, which acts as the "charge pump" for the system. An internal leak could be allowing much of that charge oil to be lost. Your best option in order to avoid throwing parts at the thing hoping to fix it is to get the Deere manual and proper test equipment and start doing the step-by-step troubleshooting the hydraulic system diagnostics section lays out. Skipping steps is not recommended, and proper troubleshooting will locate and fix the issue in the most time and cost efficient manner possible.
Bob
04-15-2007 00:32:57
