24-12 conversion
Mike in Ne
04-13-2007 19:28:38
I converted my 67 4020 to 12 volts with the Deere kit. Only problem I have is that I have to rev the engine way up to get the alternator to start charging. Tried two alternators and both did the same thing. The light on the dash stays on until 1800 to 2000 rpm, then it charges fine at all rpm"s. Ideas?????
Mike in Ne
04-14-2007 14:52:31
 Re: 24-12 conversion in reply to Mike in Ne, 04-13-2007 19:28:38
It is a three wire. Others I have spoken to have agreed with Mike's reply below of it being normal with the pulley size.
Gerald J.
04-14-2007 09:45:51
Or change to a two or three wire alternator connection instead of the one wire connection.
Gerald J.
Mike Aylward
04-13-2007 20:07:18
Mike, I know this is not uncommon on these conversions. One thing you might do is to install a smaller pulley on the alternator. This will make it kick in at a lower speed. I know the pulley Deere used to supply on their alternators was somewhat larger than aftermarket sources supply. Hope this helps. Mike
