Bucket Pins, bushings, washers, snap rings, ect
Doug in Michiga
04-13-2007 18:17:37
Hello Deere board, have a Case 580 SuperE,
Looking to tighten up loader bucket and hoe
bucket, replaceing pins and bushings. Does anyone know of a site to order pins, bushings, washers, snap rings, ect? Also how do you get old bushings out, just bang them out with a hammer? Any tricks?
TIA
Lloyd(rustnlhl)
04-17-2007 16:40:23
 Re: Bucket Pins, bushings, washers, snap rings, ec in reply to Doug in Michigan, 04-13-2007 18:17:37
Did one today....sent you an email...for everyone else..heres how just changed a set today in a 624e john deere loader...after many hours of hard work and painful labor ....We got it and the second one was easy....took 30 min. first..put NEW Bushings in the freezer over night...(Dont Laugh) Then cut a small groove in the old bushing you are taking out (not all the way through)dont want to cut the arms....then hammer out old bushing...this will now move as it squeezes it together. Clean....Then heat the end of the arm where the bushing goes in til red...a line across will do takes approx 5 to 10 min...now the fun part...you have very little time to do this part..get frozen bushing and insert it in place...it will slide right in you have about 30 seconds to get it placed evenly as you need room for the seals...long story short...heat expands the steel...frozen bushing shrunk....but doesnt take long to thaw and expand...so you must be quick...let cool then put in your seals....minus the freezing of the bushings it should only take an hour to do both sides. I to thought it was a crazy idea but it works I remembered a science class about hot and cold..that and they wanted $1500 plus taxes to do it for me.. My email is [email protected]
Glen in TX
04-14-2007 07:36:08
You would think a Case industrial dealer could get or would have the pins yet? If any hydraulic repair shops in your area check with them or local machine shops usually do cylinder repairs too and may keep some plated pins. If holes are worn very bad might consider having machine shop make oversize pins to help take up wear too. Rotate them some as Hayfarmer said when trying to drive out because center of pin will wear and get a offset lip that makes them hard to drive out.
Hayfarmer
04-14-2007 07:19:10
My JD dealer looked up bushings by id,od length etc and matched with deere. They used to have a bushing book that they used the same way. They may be able to do that with pins also and snap rings can usually be matched. As far as removal, depends upon the bushing. On the thicker ones if you can find a driver the right side you can knock them out, sometimes. On thin ones you may be able to get a chisel under the edge and roll them in. All depends upon how long they have been there and how badly they want to stay.
