jd 1020
arlyn daugherty
04-13-2007 10:06:14
have rec purchaced a jd tractor model 1020. sorry but posted earlier as a 2010 model. any background as to good or bad exp. you have had would be appreciated and esp. the use of lead additive in gas (unleaded) if is necessary or benifitial
. thanks to all you jd owners. i finally joined the club.
rrlund
04-14-2007 11:11:11
 Re: jd 1020 in reply to arlyn daugherty, 04-13-2007 10:06:14
I've got a 1020 gas that I've had for 26 years. I've used it as a loader tractor the whole time. Nothing that you wouldn't expect to go wrong with a tractor. One overhaul,one clutch job,a hyd pump repair,powersteering repair. There is a hyd block under the right hand step that likes to blow out the o-ring every 3-4 years,good idea to keep those on hand. They never blow at a convienient time or place. But,I use it everyday to load silage and manure.
dds-inc
04-13-2007 19:50:31
lead additives? no, i've been getting along just fine without any lead for 25 years
jdemaris
04-13-2007 11:18:15
Check the archives here - there have been many posts on that tractor series. 820-830-1020 Ag and 300 Industrial are all similiar - with varying options. One of the best utility tractors Deere ever made. 1020 has a smaller hydrualic pump than the 300 but otherwise basically the same tractor. If your's is gas it's got the 135 c.i. engine - same as used in 350 crawlers, 380 forklifts, etc. Came with several option packages e.g. two-stage clutch driven PTO or hydraulic independent PTO, hydraulic reverser or hydraulic hi-low, power steering, etc.
