A front spoke wheels
Lee @ Elk Mound
04-13-2007 07:14:23
I have a 1941 (#511247) A with spoke front wheels. Did all A's of that vintage come with factory spoke wheels? It seems some people refer to the spoke wheels as "cut-offs" and others refer to them as "original condition" spoke wheels. Can somebody clarify all this for me? I seem to be a novice to J.D. A's.
Also, another A that came in the package is a 1945 and the shifter implies a two-speed transmission. Is that the case? I don't have an owner's manual yet to get this basic info.
Thanks.
Lee @ Elk Mound
Lee @ Elk Mound
04-13-2007 11:00:16
 Re: A front spoke wheels in reply to Lee @ Elk Mound, 04-13-2007 07:14:23
Duane,
Thanks for all the information.
Lee @ Elk Mound
Duane Larson
04-13-2007 07:57:37
Lee,
Regarding front wheels for rubber tires, Deere changed from round spoke to pressed steel at 445325 (late 1936), and continued with pressed steel wheels of different designs until the end. Steel front wheels always had spokes, and often had the steel rim part cut off and a rim welded on ("cutoffs") when converting to rubber tires. Your A may have come on steel with a smooth hub having round spokes sticking out of the casting (and no casting number anywhere on the wheel). It sounds like it was converted to cutoffs. Your hub is often referred to as a "war wheel" as they were in common use during WWII when rubber was not available.
Your '45 A indeed has 6 speeds forward with the slots stamped 5-6 for example. You will find a lever with two positions H and L - with the lever in the L position you will be in the lower number gear in each slot, and with H the higher gear number.
