Clear Coating
Farmboy169
04-12-2007 23:09:00
Good evening. I am thinking about maybe putting clear coat on my D when I paint it. I am wondering if I can put the decals on then apply the clear coat or is that a no no. Thank you for any info.
dds-inc
04-13-2007 20:05:49
 Re: Clear Coating in reply to Farmboy169, 04-12-2007 23:09:00
do you have to use outside air system to spary clear coat, guys?
Glen in TX
04-13-2007 07:38:49
I'd say if you have to clear coat do that and then decals. You will hear some say they clear coated over decals but that was with older restorations and older paints and clear coats we used in Dupont brand but they don't make those anymore. Old Dupont deluxe clear coat worked well over water transfer decals on old style enamels then but could crack after a while in sun and then you have a mess to fix and start all over. At least with the newer vinyl cut decals on top of modern clear coats you can always go back to replace or fix a decal if needed but not with clear coat over decals.
Gary from Muleshoe
04-13-2007 05:26:00
Clear-coat first then apply decals, I would reccommend using Jorde decals. There was a 48 JD B at a show in Plainview that had these decals on it and it really looked sharp. I am going to eventually repaint my B and I will clear-coat and use Jorde decals. Clear-coat really makes them stand out in the crowd.
mjbrown
04-13-2007 04:00:49
Better try a scrap decal first on something to be sure the decal isn't attacked by the solvents used to thin the clear coat. You won't be able easily to replace the decals down the road either if that is a possibility. A clear coated tractor almost looks too shiney.
B-maniac
04-13-2007 17:47:46
 Re: Clear Coating in reply to mjbrown, 04-13-2007 04:00:49
Clear first , then decal. Everyones advise is excellent. The one addition I have is this. Decals will expand and contract in the sun and cold at a different rate than the clear over top of them and for that matter the metal under it all also. The vinyl will "give" but eventually the catylized clear coat will "give up" because it is not as flexable as the vinyl. Also a vinyl decal "breathes" through pores in it's surface. It can no longer do this if you seal it up with clear coat.Some have gotten away with it , I wouldn't chance it.
