466 versus 404?
ghgfarms12
04-12-2007 19:11:42
hey im wondering which of these is a better motor? we have always run ford tractors but are finally wanting to get a green one. we have two tractors in mind,a 4430 and a 4450. both have around 6,000 hours on them and both nice. im wondering if the 466 will be better long term and if its worth the extra 8,000 (4430 is 16,000 and the 4450 24,000) in price? Both seem to run good,and the 4450 starts better but ive heard that the 30 series start hard anyways. also,both have the quad range transmission. any information on reliability,power,etc..would be great. the more information the better. thanks.
Big Motha Green
04-27-2007 11:26:56
 Re: 466 versus 404? in reply to ghgfarms12, 04-12-2007 19:11:42
Both good motor"s, in my opinion, 466 hands down. I"ve got both, the 466 has more power, more torque and more reliable.
JMS/MN
04-13-2007 22:29:52
At those prices- go with the 50. I have both- 4430 2wd, 4450 MFWD. 30 has almost 11000 hrs, 50 has about 9000. Both are PS, original engines, tranny & rear end. 50 is newer technology. Yes, 30 is the harder to start. Had the 30 for 27 years, still uses a pint of oil every 100 hours, like when I bought it. 50 is the same or better. 4430 is overpriced by a few grand, 4450 is in the ballpark- here. My 4430 is for sale since I don't need it after getting out of livestock, but I'll advertise it for under 14 grand.
yesfrd333
04-13-2007 07:49:26
go for the 4450. ours we bought new in '88 still runs like new and it has 8900 hours. we have done everything with it and it has never let us down. we just had it dynoed last year and it produced 167 horse. definitely our best-ever tractor!
720 in pa
04-13-2007 03:41:27
definetly the 466 i aint saying the 404 aint no good im just saying the 466 is better. got more power,starts easier in winter,the only thing bad is they have their share of bottom end trouble
G/MAN
04-16-2007 18:24:05
 Re: 466 versus 404? in reply to 720 in pa, 04-13-2007 03:41:27
They do? What bottom-end trouble would that be? What's radically different about a late-404 bottom end and an early-466 bottom end? They both use the cam-driven oil pump, the strokes are identical and even the crankshaft part numbers interchange in some cases. So where's the supposed problem? I've worked on hundreds of 466-powered Deere tractors of all sizes from 4240s with 466Ds to 4850s with 466TAs, and the only bottom-end failures I've ever seen have been directly related to other issues - being ran with a lack of oil pressure, fuel or coolant contamination of the oil, etc. And only a handful of those spun bearings or tossed rods through the block.
NEIADan
04-13-2007 03:38:00
I have two 4430's and a 4450. As far as the engines either is a long life engine if kept cool. A stock 4430 is a hard starter. With an updated injector pump or new style pistond they will start as good as the 4450. My 4450 always runs to hot, water pumps have a shorter life on them. they also are not as effeicient as the 404. But 4430's can be as different as night and day in fuel. I hace a Synchro 4430 at 130 horse that uses 7 gallon hour on chisel 4.5 on the rd baler. The 4430 quad with intercooler runs a strong 170 and will use 9 gallon on the same chisel and 3.5 on the baler. The 4450 is running 155 and uses 9 on chisel and 6 on the baler. But I still bale with the 4450 because of the better ride the mechanical fronts bigger tires and the hydraulic seat really help smooth out the ride.
Also remember that 6000 hours is way different since the 4430 uses engine hours and the 4450 is clock hours. I would estimate that the 6000 clock hours would probably be only 4500 engine hours. If you could find a 15 speed powershift you would really love the 4450. The other big user friendly thing is that the 50 series uses standard ISO hydralics. Otherwise about $200 per valve to have the 4430 changed over.
G/MAN
04-16-2007 18:19:30
 Re: 466 versus 404? in reply to NEIADan, 04-13-2007 03:38:00
Maybe I'm misunderstanding you and I apologize in advance if I am, but if you're suggesting that the hours on the 4430 would be more accurate than the hours on the 4450, you're completely backward. The mechanical, cable-drive tachomters/hour-meters Deere used on the 20-series and 30-series tractors ONLY read true engine hours at rated speed - 2200 engine rpm for most of them. If you're idling around at 1100 rpm running an auger, you're only putting a half-hour on the meter for every hour the engine is actually running. Any mechanical-tach tractor will have far more hours on it than the meter shows, unless it was ONLY used for stationary PTO work and was kept at rated speed constantly. The electric hourmeter on the 4450 on the other hand, ONLY puts time on when the engine is actually running and when the instrument cluster "sees" that there is engine oil pressure, and being electrically-powered like a wall-clock, it doesn't care a lick whether the engine is running 800 rpm or 2350 rpm - it's putting on true time.
matthies
04-13-2007 18:56:57
NEIADan if your 4450 has the fan clutch, Deere has some straps to lock the clutch and make it a direct drive to help your heating problems. chris
NEIADan
04-15-2007 05:27:27
 Re: 466 versus 404? in reply to matthies, 04-13-2007 18:56:57
My fan has already been locked up. I'm afraid the only real answer is just put in a new radiator. The John Deere dealer I bought it from has never listened to the problems they just avoided any warranty work.
G/MAN
04-17-2007 16:51:10
 Re: 466 versus 404? in reply to NEIADan, 04-15-2007 05:27:27
It may sound like an overly simple fix, but I'd sure be checking the accuracy of the gauge and sender. I've seen more than one "overheating" problem that resulted in a wild-goose chase of parts replacement that were the result of nothing more than inaccurate gauge readings. There are gauge and sender checks right in the manual - the gauge should read in a certain range when certain voltage is applied to it (using a Deere gauge tester set-up), and the sender should have as specific amount of resistance at a specific temperature in order to make the gauge read write. Wiring problems could also be to blame - a bad spot in the wiring or poor connection causing high resistance will throw the gauge readings out of whack instantly. The first rule of thumb when dealing with ANY fluid temp issue is to make sure that the problem being indicated actually exists, and isn't a problem in a gauge or warning circuit.
cdr3020
04-13-2007 07:04:36
one thing i know is that the powershift isnt as efficient as a standard transmission like the quad or synchro. so you should keep that in mind. plus you have alot more weight your carrying around for the same job. my neighbor has a 4450 with quad range and it is way more fuel efficient then his 4430 powershift. as for the hours,the 4430s dont show true hours where as the 50s do. which can either be considered bad or good i guess. my vote goes for the 4450. i never hear anything bad about them,though i dont with the 4430 either. i have seen extremely high houred 4450s still going strong. if both are taken care of,either one will last a long time. have a nice day.
billyiron
04-12-2007 20:01:00
A 466 will blow a 404 in the A-s any day of the week,,,not to mention all the improvements of the 50 series over the 30,,,take the 4450,,hands down the best choice,,bar-none
Tx Jim
04-13-2007 04:10:11
 Re: 466 versus 404? in reply to billyiron, 04-12-2007 20:01:00
I'd vote for the 4450 over the 4430 for beefier differentals,hyd seat and better engine. My 4255 is great for rd baling. Tx Jim
