51 b jumps out of 1st gear
russ rolke
04-12-2007 18:41:26
i have a 51 john deere b that jumps out of 1st gear does anybody have any clues what to do to fix a friend also has a 1 50 b that they just went through all the bearings and gears and adjusted the shifter per manual and it still jumps under a load any ideas thanks
dds-inc
04-12-2007 20:31:54
 Re: 51 b jumps out of 1st gear in reply to russ rolke, 04-12-2007 18:41:26
poor shifter detents, replace spring and ball bearing in shifters. Also, shifter forks may be loose from shift rail castings.
machinery-man
04-12-2007 19:43:51
Look in archives as there are plenty of posts on this.
machinery-man
04-13-2007 04:36:00
 Re: 51 b jumps out of 1st gear in reply to machinery-man, 04-12-2007 19:43:51
You need, better top shaft, worn, locking shifters, maybe some bearings. Full explanation in the archives.
