B wheels
teddy52food
04-12-2007 10:12:38
I know of an unstyled B that has cast rear wheels & split rims. Is this common? I thought these had spoked wheels.
Duane Larson
04-12-2007 20:24:51
 Re: B wheels in reply to teddy52food, 04-12-2007 10:12:38
teddy52food,
Cast wheels (with cast-in 10-spline hubs) became available on the model B at B27435, just after the beginning of the 1937 model year (November 1937). They had a casting number B695R and used a 6.00S-36 demountable rim for a 7.50 or 9.00-36 conventional(not wide-base) tire. In my observations over the years round spoke wheels are seen much more often than the B695R cast wheels.
Pressed steel wheels became available at B81793 (early in the 1940 model year, which ran from July '39-June'40). They had rims for the new wide-base tires, 7W-38 (for 8-38 or 9-38 tires), 8W-38 (for 9-38, now 9.5-38 tires), and 9W-38 (for 10-38, now 11.2-38 tires).
Gary from Muleshoe
04-12-2007 19:40:31
If my research has not failed the cast centers did not come about until 38 or 39. At this same time you could get the pressed steel disk wheel and some flat spokes were still available also.
RLA
04-12-2007 13:57:08
Yes they were common, should also have 36" rubber.
jc37A
04-12-2007 17:39:49
 Re: B wheels in reply to RLA, 04-12-2007 13:57:08
I thought that the rear cast centers were a little more on the rare side for the unstyled A's and B's. I know that here in Georgia, I see them mostly sporting spokes.
