NEED WIRING DIAGRAM JD 530
POP
04-12-2007 07:29:26
I am in the process of wiring my JD 530, I have the ignition diagram but I need the wiring diagram for dual lights on the flat top fenders. If anybody has a copy it would make the job easier. Thanks POP
Glen in TX
04-12-2007 10:20:00
 Re: NEED WIRING DIAGRAM JD 530 in reply to POP, 04-12-2007 07:29:26
You didn't say if gas or LP but the wiring diagrams are a bit different because of the fuel solenoid setup and different switch. The parts catalog diagram Carl has may help you more as the diagrams in SM2029 Electrical cover 50-720 gas & all-fuel models or 50-720 LPG models and shows some connections or circuits that may or may not be needed on your 50.
CLW
04-12-2007 18:35:56
 Re: NEED WIRING DIAGRAM JD 530 in reply to Glen in TX, 04-12-2007 10:20:00
Glen, he was asking about a 530. SM2029 does show the 530-630-730 Gas, LP and All-Fuel to be the same when it comes to Lamp Wiring, which is all he said he needed. I sent an email needing his address to send the diagram as I can't send it through this site. Haven't heard back tho. If I do I will send the entire diagram becouse like you say, the LP is a little different at the dash.
Glen in TX
04-12-2007 22:33:53
 Re: NEED WIRING DIAGRAM JD 530 in reply to CLW, 04-12-2007 18:35:56
Yeah he did say 530 lol. Diagram for those is simple to read compared to some of the others. I didn't hear from him either so maybe you will.
Carl NY
04-12-2007 09:02:18
POP- I made a copy from the parts book and is ready for you to pick up.
Pete in MD
04-12-2007 08:11:49
Pop,
The diagram you need is on page 80-5-23 of SM-2029. Check with your JD dealer, he should have it.
Pete
