430U hydraulics
Hayfarmer
04-12-2007 07:26:32
I have a #35 loader on my 430. I put hydraulic tilt on the bucket but seems like it is really slow. I think the pump might be getting a bit worn after many years of use. What was the original GPM on that pump? I am thinking about installing a front mount, crankshaft driven pump for loader, but that makes it harder to take off and put on..
JD@Antique Acres
04-12-2007 11:17:06
 Re: 430U hydraulics in reply to Hayfarmer, 04-12-2007 07:26:32
I also put a hydraulic ram on my 35 loader. I guess my first question is what is the diameter of the ram? I don't remember off hand what GPM are on the pump, but if you have too large of a ram that pump will take awhile to fill it with oil, thus making it slower.
mike,indiana
04-12-2007 13:22:59
 Re: 430U hydraulics in reply to JD@Antique Acres, 04-12-2007 11:17:06
The hydraulic system on the 430 was poor at best.
It only contains about 3 gallons of oil to start with.Some loaders would require an extra tank for enough oil capicity to run the loader and hydraulic bucket.Adding a front or rear pump would be better,but then with the extra power you might break the front end,another weak spot.
