Gasket Thickness
RonRod
04-11-2007 18:33:20
I see a number of references to "thin", "medium" and "thick" gaskets in the JD manual and here. Can someone quantify what thickness these gaskets are. Like is the "thin" a 1/64" gasket. Medium 1/32" etc. Thanks once again.
Ron
P Brwoning
04-11-2007 19:57:29
 Re: Gasket Thickness in reply to RonRod, 04-11-2007 18:33:20
You got it! Thick gaskets is 3/64-inch thick. While the parts catalogs are pretty good, I do not give them high marks on gasket & shim call-outs. Some things you just have to be able to figure out on your own I guess. In general, I usually suggest using 1/32-inch thick (medium) gasket material except in certain places, and in those places, I go with the dealer-supplied item. Two examples here are the B246R oil pump gasket and any oil filter cover gasket. Main bearing gaskets and radiator gaskets plus any large gaskets are a bargain when bought in the "market place." (PatB)
