5500 pto won't work
Farmer7597
04-11-2007 17:58:29
Can't turn on the PTO. I disconnected linkage and with pipe extension on flange, but still minimal movement...had not used PTO for 1.5 years. Could it be just rusted?
Farmer7597
04-16-2007 17:57:05
 Re: 5500 pto won't work in reply to Farmer7597, 04-11-2007 17:58:29
Never mind, I should have been a mechanic, I figured it out myself because no one answered my post. So, for the benifit of the cause, here is the answer. There is a known problem created when the clutch splines are assembled dry. Rust can build up between splines on the traction shaft and traction clutch hub splines. Word to the wise, when you JD dealer replaces your clutch for this series of JD tractor, make sure they know to apply a moderate coat of moly high temperature grease on the traction shaft, traction clutch disk hub, PTO shaft and PTO clutch disk slines. Ensure that 100% of the spline contact area is covered with grease to prevent rust.
JD grease comes in three sizes: - 14 OZ. TUBE TY6333 - 1 LB. CAN TY6347 - 35 LB. CAN TY22017
