follow up on 720 turbo
720 in pa
04-11-2007 09:15:03
thanks guys for directing me to garry power for larger injectors i guess i need to provide photos of my 720 turbo because apparently some people think no such thing exists since i read all the follow ups on that subject. dont know why somebody would ask questions about something that doesnt exist
Steve M
04-11-2007 14:29:30
 Re: follow up on 720 turbo in reply to 720 in pa, 04-11-2007 09:15:03
We pulled a F145 semi mount 4-14" in heavy black eastern Iowa ground. Could get by with 4th in bean ground and some corn ground,3rd gear on sod. Usualy when it ran warm was when you used 4th,it worked the snot out of it!
JLG
04-11-2007 14:20:21
Sometimes people post on here just to get conversation going, they might have thought you were going for that. The last pull I went to last year had a turbo"d 830 JD. I hope he brings it back this year, I"d like to get a closer look at it. He had the same trouble you said, needed some more fuel. I would like to see some pictures of your set up too if you ever get a chance to post some.
GPULLER
04-11-2007 11:13:29
Not a problem, glad to help. I think you'll like the injectors from Garry.
Keep me posted on how they turn out for you.
JDBert
04-11-2007 12:35:57
 Re: follow up on 720 turbo in reply to GPULLER, 04-11-2007 11:13:29
Gpuller-
when you getting a turbo?? Mighta helped ya at lincoln, maybe the vid would have been alittle longer then 43 seconds!!!!
GPULLER
04-11-2007 12:57:06
 Re: follow up on 720 turbo in reply to JDBert, 04-11-2007 12:35:57
Bert, what have I ever done to you??
Should have had duals or chains, that might have helped me way better!
JDBert
04-11-2007 12:58:55
 Re: follow up on 720 turbo in reply to GPULLER, 04-11-2007 12:57:06
I had the PERFECT set of duals for ya BUT NOOO you didn't wanna use them!!!
Steve M
04-11-2007 11:02:14
Does it have enough radiator to keep it cool? I ran my Dads 730 diesel all through high school and when you worked it real hard in hot weather you could get it up to 220-230,didn't seem to hurt it. That was after a new radiator because a fan blade went through the original. Good tractors !
720 in pa
04-11-2007 11:33:48
 Re: follow up on 720 turbo in reply to Steve M, 04-11-2007 11:02:14
had it out plowing two weeks ago never took it up farther than 190.it probably would have gone higher if i wouldnt have shifted from 4th to 3rd.i was pulling a 3x14 trailer in clay type soil
