JD A vs. JD AR
KRUSS1
04-11-2007 09:14:12
I am new to JD vintage tractors so this is no doubt a really stupid question. What are the differences/sinilarities to an A and a AR? Also years of mfg and hp?
Glen in TX
04-11-2007 14:01:45
 Re: JD A vs. JD AR in reply to KRUSS1, 04-11-2007 09:14:12
Sounds like you are covered on explanations but if you buy yourself one and need more info on what may or may not interchange you'll find that in Model A parts catalogs. One catalog covers all variations of the unstyled A, AR, & AO models and another catalog covers the styled versions of A, AR, & AO. There were separate operators manuals though for A row crop and standard tread AR & AO. The other rare bird is the early AOS covered in it's own separate parts catalog and operators manual too.
1951g
04-11-2007 09:52:03
The AR was made from 1935-1952. The A was made from 1934-1952. The AR has a wide front end with a standard tread and also more sheet metal since it came with fenders. You could get fenders for the A but they didn"t wrap around as far as the AR. The seat sits further back and you"re lower to the ground. It"s pretty much a smaller version of the D. It was produced mainly for midwest crops whereas the A was for row crow farming. The A also came in different configurations such as tricycle gear with 2 wheels together, a single front wheel (AN), an adjustable front end with wide settings (AW). The engine is pretty much the same for the A and AR. Actually there are some parts you can swap between the 2 if you"re restoring one. These are the basic differences, but someone else can chime in and tell you more. There are also pictures under the photo gallery. Just type in A and AR and you"ll get back lots of photos.
1951g
04-11-2007 10:00:30
 Re: JD A vs. JD AR in reply to 1951g, 04-11-2007 09:52:03
Sorry, forgot to give HP ratings. The ratings were the same for the given year for both the AR and A. They also styled (streamlined) the AR and A. The A was styled in 1939 and the AR in 1949. There is a site called Link that will give you the stats on the A/AR when you get to this site, you should see stats on the left side of the webpage. Click on the model and it will give you more information. When the A came out in 1934, it was around 18.7hp drawbar and 24.7 pto/belt.
KRUSS1
04-11-2007 10:54:04
 Re: JD A vs. JD AR in reply to 1951g, 04-11-2007 10:00:30
Thank you. We have mostly AR s in our area but A's are turning up at auction sales. From a distance I know what each looks like just the similarities I wasn't sure about. Sounds like the parallel of IH H and W4 or M and W6.
