4020D Pump Coupling Follow-up
Leon W
04-11-2007 04:41:54
I removed the clamp coupling and just as the replies to my original post noted, the bushings were wore on the pump side and the clamp was making contact with the pump side coupling. It only took about 15 minutes to remove. I will get my parts today and have her back in servce again soon.
Thank you to all who replied! The knowledge available for free on this website is fantastic.
msb
04-11-2007 07:38:35
 Re: 4020D Pump Coupling Follow-up in reply to Leon W, 04-11-2007 04:41:54
Use a sharp knife to cut the bushings off and use a hammer to tap those nylon bushing on.Also be sure to tighten both sides of the coupling equally.
JMS/MN
04-11-2007 13:18:45
 Re: 4020D Pump Coupling Follow-up in reply to msb, 04-11-2007 07:38:35
A locknut on the bolt doesn't hurt either- then they don't work themselves loose.
