4020 second hydraulic remote
Chuck H Wi.
04-10-2007 21:25:41
I would like to add a second hydraulic remote to my 1965 4020. Is it hard to do,anyone know roughly what it would cost, and would anyone know where to get a hold of one. It has the hydraulics on the dash. Im in Wisconsin. Thanks, Chuck
Gerald J.
04-11-2007 10:42:04
 Re: 4020 second hydraulic remote in reply to Chuck H Wi., 04-10-2007 21:25:41
There are two other options besides the factory (used, new, or rebuilt) parts.
There are electrically operated doublers that connect two loads to the single existing valve. One source is Shoup, www.shoupparts.com
The least expensive is to tap the pressure line just in front of the brake pedals with return to the transmission oil filter cover and mount a closed center valve on the right fender with outlets as needed. Just like plumbing in a loader with its own valve. I'd mount that new valve under an arm rest with the handles reversed. It could add one or several outlet pairs. Pioneer makes a better couple under presssure pair that the Deere couplers, and its used by other tractor makers.
Gerald J.
Bob
04-11-2007 17:11:09
 Re: 4020 second hydraulic remote in reply to Gerald J., 04-11-2007 10:42:04
Unless the tractor has a 3-point, the line metioned by Jerold won't be there. There are two other easy places to tap into, in that case, however... the bottom of the steering priority valve, or install a "T" at the top of the SCV under the hood.
msb
04-11-2007 07:54:51
Its not hard to do. I installed dozens of them back in the 60s.Worst part is keeping the two square packings on the box in place when attaching the second box. I always used heavy wheel bearing grease to keep the dripping oil from washing them loose and falling out of place.
nickg
04-11-2007 06:53:24
I had thought about this my self.Found a kit for $800 from wengers i think cant remember looked at so many. It had the hoses, scv for two outlets and the remote outlet. no lever or linkage. After doing some research i just bought a fosse valve. Less expense and less time to install
MSM
04-11-2007 01:15:22
Your best bet would be a salvage yard. Have them pull the entire second setup off a salvage tractor. It will be considerably cheaper than trying to piecemeal all the seperate parts from different sources.You need lever,valve assembly,linkage,lines,clamps,bolts, and the remote. Then it will be 3-4 hours of work to install.
