310 Backhoe rebuild
Hogman
04-10-2007 16:32:48
Below is what I had posted before with one answer..... .I took the head back off, had it checked by a very good specialist..... Head is perfect..... ....Have new gasket to put on..... Anything else that we should check before it is put back together.....What else could be making it build up pressure????? ?? He also took the injector pump to have it checked again..... They said there was grindings or shaving in it...What is that from????? ?He is really frusterated with this since he is goin to be needing it pretty soon..... .Any help will be used wisely..... ...Thanks to all Scott
Hogman 03-22-2007 09:13:58
69.40.232.106
234258
Delete
This is a JD 421 motor....He bought it rebuilt and assembled.....Always had trouble starting ( have to use either ) Replaced Fuel Pump,Primary Pump,Injectors,Radiator..... .It has been pushing water out the Radiator Overflow..... .Why is it building up so much pressure?? Any input will be helpful..... ..Thanks guys [Reply] [Send Email] MSM 03-22-2007 10:11:10
62.12.37.3
234262
Delete
It could be a number of things either stemming from the "rebuild" or the use of ether. If the cylinder head was not rebuilt properly with the correct valve standout, the engine will be very hard to start.Just grinding the valves and cutting the seats drops the valve down in the head,effectively dropping the compression making for a hard start. Building up pressure in the cooling system can be caused by a blown head gasket,or cracked head. It would probably pay to pull the head and have it checked by a reputable machine shop for cracks,flatness and valve standout. Also while it is apart, I would also pull out the pistons and check for broken rings from excessive ether application. Recheck the injection pump timing also as being out of time either advanced or retarded will cause a hard start. With the head rebuilt correctly,pump timed up correctly and good rings and a good cranking speed that engine should start unassisted down into the teens.
Jonathan in MA
04-11-2007 05:36:14
 Re: 310 Backhoe rebuild in reply to Hogman, 04-10-2007 16:32:48
What is the condition of the dowel pins on the deck of the block? They are what align the head gasket. The rear one tends to erode more than the front for some reason. Try a new "known good quality" head gasket and fit it on. It should be tight around the 2 dowel pins.. The head isnt tight on the pins as it uses the head bolts for alignment... just another thing to check...
720 in pa
04-11-2007 04:22:18
a good way to tell if you actually have compression in the radiator is warm the engine to operating temperature slowly remove radiator cap with engine at an idle.if you can see bubbles coming up out of the water you have compression in the radiator. I have seen a lot of them you cannot fill the radiator up to the top. try running with water level half an inch down from radiator neck.
Handyman
04-10-2007 21:14:08
Has the head AND the block been Magnafluxed to check for hairline fractures. does it have wet sleeves in the block, Deere has had a problem with some engines cavitating around the the sleeves causing tiny pinholes to develop which would allow compression and exhaust gasses to pass into the water jacket.
Jim Presley
04-10-2007 16:59:26
Hogman. A couple questions and a simple thing to try in regards to the escaping water. First of all, is the only abnormal event that water is coming out of the radiator cap? What I mean there is, is the temp OK, oil pressure OK, etc.? Has there been any oil in the water, or water in the oil? As simple as it sounds, you may just have a failing cap that releases pressure way too early. Make sure the top of the radiator neck is smooth and flat with no damage as well so the cap can seat well. Usually, externally induced pressure in the cooling system has more than one indicator of where the problem is. It is either in the head, or the block. Is the new head gask the same as the one you just took off? I'd compare them just for the heck of it, the older one may have been incorrect... If the escaping water is from an overheat condition, that will send you in additional directions as well. Thermostat, blocked hoses, passageways, water pump etc.
Any other signs at all other than the escaping water from the cap?
The hard starting could very well be a faulty pump condition. Shavings in there are not good, they should be able to tell you what they are. Others here are much more experienced with those pumps that I am, so I will let them add comment.
Let us know what you find, good luck!
Jim P
Hogamn
04-10-2007 17:44:38
 Re: 310 Backhoe rebuild in reply to Jim Presley, 04-10-2007 16:59:26
Jim, As soon as it starts it is pushing water....New Rad and Cap..... ...No warm up nessasary.....Scott
