730 Tapered Flywheel Nut
Charles Beavers
04-10-2007 13:00:20
I have a JD 730D that I bought restored. I heard this model is known for the flywheels working loose. How do I know if I have the new tapered nut (what does it look like)or just the original factory locking nut? I am not having a problem but want to take the cover off and check. The tractor has 4280 hours and if the original nut is still on does that mean I probably won't have a problem?
Thanks...Charles
Charles Beaverson
04-11-2007 13:54:43
 Re: 730 Tapered Flywheel Nut in reply to Charles Beaverson, 04-10-2007 13:00:20
Thanks again for the great responses to this post. One more question..does anyone know what the torque should be when you check the bolts for correct tightness? Since I first posted, I now have the flywheel cover off and the flywheel does not have any looseness..either in and out or side to side.
Charles Beaverson
04-10-2007 16:55:23
Thanks for the reply. My 730 has two bolts and a metal nut that threads onto the shaft spline. The nut looks like a thin metal nut with the edges rolled to form a hex for wrench tightening.
Is this original equipment?
DSK
04-10-2007 21:20:49
 Re: 730 Tapered Flywheel Nut in reply to Charles Beaverson, 04-10-2007 16:55:23
Yes, this is the original setup. Check the bolts occasionally to make sure they're tight and you should never have any flywheel problems, and congratulations on buying one with a good flywheel. Use the decompresser to shut off the tractor, this is much easier on the flywheel and crank than shutting it down under full compression.
mjbrown
04-10-2007 16:08:05
I'm guessing you are refering to a taper-loc which is in most cases a different flywheel. Some Deere flywheels I guess have been machined to have a tapered hub. The taper-loc will have a big square nut on the end of the collett or hub and no bolts in the flywheel.
buickanddeere
04-10-2007 14:55:16
The main cause of loose flywheels is a Mr. Tinkerer who wouldn't know what a torque wrench was if he was hit with one. Re-torquing a flywheel without a torque wrench will either,have the bolts too loose and the flywheel shakes loose. Or the bolts are tightened too tight and are stretched. Then the flywheel works loose. New grade five or grade eight bolts should be used everytime a flywheel is torqued down.
CPeter
04-11-2007 05:35:41
 Re: 730 Tapered Flywheel Nut in reply to buickanddeere, 04-10-2007 14:55:16
One of the key things that B&D said is that thee bolt should be replaced with new. That is EVERY TIME they are removed. They should not be reused. Part of the torquing is a stretching of bolts that permanently changes them.
CPeter
