39h with x,s
WILL JD MAN
04-10-2007 12:08:42
I have 39 h that has an raised x on the axle housing on both sides.I have not see any other h,s at shows last year have them. One guy said that the tractor might be an experimental one. Any help on this guys.Thanks Will.
George S. in the real NY
04-10-2007 17:28:46
 Re: 39h with x,s in reply to WILL JD MAN, 04-10-2007 12:08:42
Would you be willing to put the serial number here? I got 4404 and don't recall seeing any special numbers on it.
WILL JD MAN
04-10-2007 19:06:53
 Re: 39h with x,s in reply to George S. in the real NY, 04-10-2007 17:28:46
This h is a 5052. The x,s are seen from the back of the tractor on the flat part of the axle housing out on the end. They are raised up like the part numbers on the tractor. Thanks Will.
P Browning
04-10-2007 14:40:21
Will -- Please write me with some more details. My email should be open. Also I would give Two-Cylinder a call and seek the Production Record on that tractor. It's very possible it was built from what was some other early JD-H tractor -- many of them out there!
Also visit the JD-H Restoration Site (below) to see if there are more details about the 39-H that you didn't know of. Scroll down to hte bottom (left) and you will find the 39-H selection.(PatB)
