JD 1020 D -- adding hydraulic remote
DarwinCam
04-10-2007 11:26:36
I've been lurking around here for sometime...and really appreciate all the info.
How feasable is it to add the remote to a 1020? At present it doesn't have any and I'd like to consider it. What do you think?
Darwincam
04-10-2007 19:41:11
 Re: JD 1020 D -- adding hydraulic remote in reply to DarwinCam, 04-10-2007 11:26:36
Hi Mike,
I think I'd go with a double acting...it seems like in the long run it would have more flexibility. Ultimately down the road, I'd like to consider a loader and maybe a log splitter.
I've not had much luck calling salvage yards for parts...to date no luck.
Mike M
04-11-2007 05:57:26
 Re: JD 1020 D -- adding hydraulic remote in reply to Darwincam, 04-10-2007 19:41:11
Shouldn't be much problem to just buy a closed center valve from northern hyd. or somewhere like that. Then go to JD and by a ported filter cover for the return and the fittings needed to hook a loader into that model. These should be in the parts books on the loader or maybe even on the tractor. You can put quick couplers on the pressure and return tractor ports since it's closed center hyd. and then just mount your valve on your implement and then just a matter of plugging in 2 hoses.
Mike M
04-10-2007 11:32:27
Do you need to operate a double acting cyl. or just a single like on a haybine ?
JD offered a kit for both but by now should be NLA you may find a selective control for double acting at a junk yard,or you can plumb up a single acting one pretty easy but it uses the rockshaft control to run it and you can't use the 3pt. at the same time as the cyl.,or maybe just plumb up a seperate valve like used for a loader and then run couplers from that. Just remember to get a valve for closed center systems.
