4020D Pump Coupling
Leon W
04-10-2007 10:23:08
My 4020D sounds a little noisy up front. It sounds to me as if the coupling on the hydraulic pump to the crank shaft is where the noise is coming from. It's a clattering type of noise. I have only done a very quick check and it seems as though the coupling is not loose. It's a litle hard to get at. Does anyone know if the coupling is a common problem? I don't see anywhere to lubricate it. I will make a more through inspection on the weekend but would appreciate any feed-back on the clattering noise up front.
flying belgian
04-10-2007 19:40:04
 Re: 4020D Pump Coupling in reply to Leon W, 04-10-2007 10:23:08
Not familier with the 4020 but on the 2440 if you don't put lock tight on the bolts and one comes loose it tears a hole in the bottom of the radiator. Guess how I know that.
msb
04-10-2007 17:49:30
I bought a 24" 3/8 drive extension a long time ago, just to take those bolts out of the coupling. Sure makes it a lot easier and quicker.
K.B.-826
04-10-2007 16:41:23
Bob's right, they're not terrible to take apart (change your fan belt while you're at it). Replace anything questionable, but definetly replace the two halves of the coupler, and the four plastic/rubber bushings. Get new bolts/locknuts, and make sure you get them tight.
Bob
04-10-2007 10:36:51
Yes, the hydraulic pump coupling is a common source of noise. It DOESN'T need lube.
There are 4 "do-nuts" inside the aluminum clamp which is held together by two bolts... used to be a sort of rubber, newer ones are a sort of pastic.
They are not expensive and are easy to replace.
Unfortunately, sometimes the front cast iron coupling half gets worn loose on the hydraulic pump shaft spline.
SOMETIMES tightening the clamp bolts will help, at least for a while. If the wear is severe, the coupling half and probably the pump shaft will have to be replaced, too.
