PTO doesn't work with the reverser on a 430
JimFromWA
04-10-2007 09:46:22
On a 430 Utility the PTO stops turning when I disengage the reverser.
What is your do you think happened?
Mike M
04-11-2007 05:59:19
 Re: PTO doesn't work with the reverser on a 430 in reply to JimFromWA, 04-10-2007 09:46:22
I had a 440 with reverser and it had no neutral ? It was either forward or resverse ? Not sure ,but I'd think the 430 would be the same ?
buickanddeere
04-10-2007 14:51:30
Has it always done this? Are you aware the pto is tranmission driven instead of engine driven?
JimFromWA
04-10-2007 17:55:05
 Re: PTO doesn't work with the reverser on a 430 in reply to buickanddeere, 04-10-2007 14:51:30
I though I remembered that the PTO would turn if I had the reverser in neutral and the clutch out, now it only turns with the reverser in gear.
