Cab for a 52 B
Crude K South B
04-10-2007 09:03:32
Dad wants to put a cab on his 52B. I am looking for an inexpensive hard cab so he can use it in the winter to plow snow. Any suggestion on what will and won't work for the B. I can build all the mounting brackets that may be needed. Has anyone else put a hard sided cab on a B? Any and all help is apperciated. Thanks!
johns48jdb
04-10-2007 15:11:50
 Re: Cab for a 52 B in reply to Crude K South Branch, 04-10-2007 09:03:32
have you thought of just adding a wind breaker with a wind shield. then you could add you a top from anything and make it ease to remove in the summer and still keep you warm in the winter. i haven't seen any of those in a long time but they use to put them on ih tractors a lot down here in n al. i don't think you'll have to close the back in because the best i can remember about them is that it gets plenty hot in behind them.
Glen in TX
04-10-2007 15:55:46
 Re: Cab for a 52 B in reply to johns48jdb, 04-10-2007 15:11:50
Femco still makes weatherbrakes.
almrm
04-10-2007 14:09:09
I installed a Year Around cab on my 3020. The cab was designed for the tractor, however, I think it would be a good choice for your B. The rear mounts clamped to the rear axle with U bolts 2 per side. Your square axle B would be similar in this area. You would have to fashion brackets for the front corners. You would have clearence around the platform and around the hood that you would have to deal with. Mine did not have heat but the powershift transmission keep it cozy in there (and unbearably hot in the summer) The B will not produce any real heat from the transmission so you will need a heater. You might also check on the aftermarket solid cabs for compact diesel tractors. A good source is Curtis Cab. An internet search will take you to their web site.
Hope this helps,
Mark
