720 pto clutch disk facings
GeorgiaHayFarmer
04-10-2007 07:53:14
Who is a good source for pto clutch disk facings for a 720 John Deere tractor? Has anyone been successfull in refacing the disks with fiber and glue?
Scott
Kent Petersen
04-10-2007 16:01:41
 Re: 720 pto clutch disk facings in reply to GeorgiaHayFarmer, 04-10-2007 07:53:14
WTR Parts has the lined & the steel plates for jd tractor PTO and engine clutch linings there #605 589 3128 email www.wtrparts.com Tyndall SD
720 in pa
04-10-2007 08:53:50
I think you can get them aftermarket through A&I Products online
GeorgiaHayFarmer
04-10-2007 11:38:36
 Re: 720 pto clutch disk facings in reply to 720 in pa, 04-10-2007 08:53:50
Hello,
Yep, you can get the disks and the disks with facings from A @ I. Has anyone ever heard of the distributor called High Capacity? I was told you could get the clutch parts from them as well. Thanks for the help fellas.
Scott
55 50
04-10-2007 08:13:59
I think JD still has them. Not sure of any after market place. What type of fiber would you use? Seems the thickness would be somewhat critical to get the clutch adjustments set correctly. If you're willing to experiment and can stand the time of a possible malfunction, it might be worth trying your own fix.
