DTLX carb Question
MJN in OH
04-09-2007 17:26:47
We have a 1959 630 standard that has a DTLX 109U5 carburetor on it. Is this the correct carb for it? Thank You for any help.
MJN in OH
04-10-2007 10:06:19
 Re: DTLX carb Question in reply to MJN in OH, 04-09-2007 17:26:47
Thanks for the replies. This carb runs good on the high end but will not idle. Idle circuit might be plugged considering what tank looked like on the inside. We put a spare 60 carb on it and it seems to run fine. I believe it is a DTLX 81. Do you think there will be a problem using this carb. Tractor runs good at a idle and at full throttle. Thank You again.
machinery-man
04-10-2007 06:47:37
For information purposes a friend of mine had one on a 530 and it was way too rich. He didn"t know the problem till we check the tag. He bought the correct unit and tractor ran properly. On a 630 this might be okay with the increased jet size. I know the correct carb for you tractor is pricy...I think they are getting around $400-500 used....
Glen in TX
04-09-2007 18:06:09
DLTX-94 came original on 620 & 630 gasoline and DLTX-97 came on 620 & 630 all-fuel tractors. That DLTX-109U was a universal duplex replacement carb for 50-70 and 520-730 tractors so yes the correct replacement carb for it. Runs good ? Not broke? Leave it!
machinery-man
04-09-2007 17:42:09
Nope...the correct model is DLTX-94 I believe you have one of the universal models...but not model specific....
