2240 Fuel Gauge
Pete/ME
04-09-2007 02:57:07
Putting the 2240 (#183999) back together after service-fluids, filters leaks etc... the fuel gauge clicks to the "full" position (only put 5 gals. in) when I turn the key on (not started). Gone over the wiring diagram in the SM, and it's got me baffled. It worked before alththough the needle always bounced around. Disconnect power and/or sender wires and the needle goes back to "empty" after about 30 sec.. Does the same even when I disconnect the sender lead at the tank. Sender or gauge? or have I cooked something by mis-wiring something.
720 in pa
04-09-2007 13:00:30
 Re: 2240 Fuel Gauge in reply to Pete/ME, 04-09-2007 02:57:07
the fuel guage sender wire operates on ground and it sounds like the wire is rubbed through or shorted out somewhere
Pete/ME
04-10-2007 02:51:27
 Re: 2240 Fuel Gauge in reply to 720 in pa, 04-09-2007 13:00:30
Bang on! Did a continuity, sender to gauge...na da. Broke in the bundle, what are the odds on that, but ran a new wire, and works 5X5. Thanks.
