4010 Issues
Vern Karman
04-08-2007 15:22:22
Have a '62 4010D with 6900 hours on it with a really good starting and running engine but ever since I bought the tractor there has been a very slight oil seepage from between the block and the head on the injector side just above the pump. Want to paint the tractor but would like to fix this leak but hate to remove the head. Any ideas?
There are also times that my clutch doesn't release all the way which can make it tough to shift unless the engine is idled way down. Anything I can do without splitting the tractor?
G/MAN
04-08-2007 15:42:28
 Re: 4010 Issues in reply to Vern Karman, 04-08-2007 15:22:22
No, there's probably no "band-aid" fix that's going to stop the oil leak for any length of time, if at all. As for the clutch, you can remove the inspection cover and take a look at the fingers, release bearing and so forth and try to determine what might be causing it to hang up. But once again, you could very well find that fixing it correctly requires splitting the tractor. If it's a good tractor, gives good service and you plan to keep it, which apparently you do if you're going to invest in painting it, it deserves to be fixed correctly. Niether splitting it for clutch repair or replacing the head gasket are huge undertakings.
