2510 batteries?
pwd
04-08-2007 07:43:57
i need to replace the batteries in my 2510. now it has 2 6 volt batteries wired in series to get 12 volts. is this right or should it be 2 12 volt batteries in parallel?
Glen in TX
04-08-2007 10:38:27
 Re: 2510 batteries? in reply to pwd, 04-08-2007 07:43:57
Unless early ones came with two 6s ? 1966 2510 diesel we had used two narrow 12Vs. Parts catalog shows that also.
TY21733 DRY CHARGED BATTERY AR (12-VOLT) 60 COLD CRANKING AMPS AT -18�C (0�F) 130 MINUTE RESERVE CAPACITY AT 120 AMPS (1 USED GASOLINE) (2 USED DIESEL) (DO NOT ACTIVATE UNTIL PLACED IN SERVICE) (SUB FOR TY6121 OR AR46115)
TimS in Mo
04-09-2007 08:35:01
 Re: 2510 batteries? in reply to Glen in TX, 04-08-2007 10:38:27
Count the caps on the batteries, 3 caps is 6 volts, 6 caps is 12 volts.
