1929 GP clutch
Marty Z
04-07-2007 22:16:51
I am as far as I can go with this clutch. I have replaced the disks,pins,dogs, springs and cleaned everything I can.Holes for pins look tight.. Still will not snap in right . When I adjust it when sitting still, then drive it it gets so loose it will not grab. I saw an article in 2cyl Mag. that dealt with clutch overhaul. I think it might be beyond my shop resources, and my ability. Is there a place I can send the whole thing to , to be re-built? I am just east of Toledo Ohio.
Thanks
Marty Z
Curtice Ohio
Duane Larson
04-08-2007 07:23:01
 Re: 1929 GP clutch in reply to Marty Z, 04-07-2007 22:16:51
Marty,
Is the drive pin to the operating sleeve loose or worn? You can check when the pulley is off by trying to rotate the operating sleeve relative to the pulley - there should be very little movement - if the pin/hole in operating sleeve are worn or loose the dogs don't stand up straight when snapping over center and that can be one source of your problem. It may be fixable by drilling a new hole in another boss of the operating sleeve (there are three bosses) if the pin is not loose.
Marty Z
04-08-2007 07:37:04
 Re: 1929 GP clutch in reply to Duane Larson, 04-08-2007 07:23:01
I have not checked that. Never knew that pin existed till I read that article. I guess it's time to take that Belt pulley out for the 10th time.Not afraid to do the work- just needed some direction. Thanks
MJZ
