52B hydraulics
ohio dick
04-06-2007 20:59:17
Can you remove hydraulic pump without draining transmission.I need to check gears for wear.
Mike M
04-07-2007 19:58:32
 Re: 52B hydraulics in reply to ohio dick, 04-06-2007 20:59:17
I think you can but you have to leave the pto shaft in place. Some may still leak past the shaft (shouldn't be much ) as I think a spring is behind the gear that pushes on a mechanical seal which is just a collar rubbing against a bushing ? or something like that.
