Checking tire pressure.
JackfromVA
04-06-2007 11:08:06
Is there anything special one needs to do to check the tire pressure in loaded tires? Any special pressure gauge or other equipment?
Thanks
Jack
RalphinWI
04-09-2007 12:21:18
 Re: Checking tire pressure. in reply to JackfromVA, 04-06-2007 11:08:06
I would say buy a gauge meant for fluids, then rinse the gauge and wash the area around the valve stem after checking the pressure. Up,down, or emptied - I have yet to see a tire that could not spit a bit of fluid into the gauge and or onto the rim if it ever contained fluid.
Pete/ME
04-07-2007 03:21:44
What are you using for pressure? I've got loaded 14.9-28's on my 2240, and they're looking a little slack.
RalphinWI
04-06-2007 23:04:26
hope farmer
04-06-2007 16:30:38
An old timer mechanic told me once that all he did for a quick check was to measure the height of the rim from the ground when the tractor was parked on dry ground. I guess you would first have to establish the height when you know you have the right tire pressure.
Gary from Muleshoe
04-06-2007 12:12:50
I believe they do make a gauge for this, but it really isn't necessary. All you need to do is put the valve stem to the top, and check pressure. If you have to check with stem down, just rinse the gauge real good in water.
55 50
04-06-2007 13:25:47
 Re: Checking tire pressure. in reply to Gary from Muleshoe, 04-06-2007 12:12:50
One further small piece of info is that when the valve stem is at the top, just press the valve core momentarily to let out any chloride solution that may have seeped into the stem. That will keep it from getting into your pressure tester.
RayP(MI)
04-06-2007 16:35:34
 Re: Checking tire pressure. in reply to 55 50, 04-06-2007 13:25:47
Or better yet, shoot a short blast of compressed air IN, blowing any liquid into the tire, then check with usual tire tester.
