G/MAN 9000 series tractors
ram ranch
04-05-2007 21:15:23
I might have found an early tractor, Maybe in 20 years it might be a gold mine? Need to find out what was first?
G/MAN
04-06-2007 07:38:10
 Re: G/MAN 9000 series tractors in reply to ram ranch, 04-05-2007 21:15:23
I couldn't come up with much. You might contact your local Deere dealership. But from experience with Deere's serial numbers, if it's in the low 1000s, it's probably pretty early. Whether or not it's going to be worth more than any other 9000 in the future is questionable. In 20 years it could still very well only be valuable as a field tractor, and maybe LESS valuable than others based on how its equipped, its condition and hours, etc. I don't know of any collectors currently scouring the earth looking for early 50-series tractors, if that's any indication. I also don't really foresee a day when guys are hauling 40,000-lb. 4wd tractors to shows in any great numbers. Sure, there are 8010s, WAs, 7020s, 7520s and the like that hit some shows, but those are a little different story. I for one am not real big on the whole "first/last" issue. I understand guys that are and don't have any problem with it if they want to spend outrageous amounts of money on a first or last tractor, but it's not something I'm really into. The lines "only one can be the first" or "only one can be the last", only hold water until you stop to think that only one can be 956th, 10,004th, etc.
ram ranch
04-06-2007 10:58:02
 Re: G/MAN 9000 series tractors in reply to G/MAN, 04-06-2007 07:38:10
True.But this tractor has the 10.5 liter motor in it, so it could be the first tractor that Deere put the motor in. Which they no longer use the 10.5. This tractor is fully equipped with all the opitions for the time. I understand nobodys going to be hauling a 40,000 lb 4wd around. But I just found it interesting. Did Deere use the same serial numbers for all the 9000 series and just changed the model number on the tag? so you could have a 9400,9100 than 3 9300 come down the line would the numbers be conceitive. The early 9000 would already be 10 years old. just a thought? Would Deere have sold the first couple that they maded or used them for shows? or testing?
G/MAN
04-06-2007 13:39:14
 Re: G/MAN 9000 series tractors in reply to ram ranch, 04-06-2007 10:58:02
It depends - generally "production tractors" - i.e. ones with a regular serial number tag and Product Identification Number (PIN) are sold to end users - eventually. Obviously one has to go to Lincoln, NE to the Test Lab to be tested, some probably made the "show circuit" and got carted around the country hitting farm shows and Deere's new product intro shows, etc. Perhaps they keep one or two production units to continue field tests with, but normally by the time they're in serial production, the bulk of the testing has been done with pre-production tractors and prototypes. I can't say for sure on the 9000-series 4wds, as we only have a few around here, but I know for a fact that the 8000-series row-crops have "interspersed" serial numbers - serial #1000 could be an 8100, #1001 an 8400, etc. The Product Identification Number tags for those tractors are RW8X00P00000 - RW is the designation for Waterloo Row-Crop tractors, I believe. P designates "powershift" transmission, and of course the last five digits are the actual serial number. I suspect 9000s are the same, but I could be wrong. I suggested you contact your local dealer because I don't want to potentially get in trouble for stating that serial# so-and-so was a 9X00 and so forth, particularly as the tractor is owned by someone and they might take offense. All I will offer is the following opinion - if the tractor in question is PIN #1000, then there's a good chance it is the first "production" 9000-series 4WD.
ram ranch
04-06-2007 13:47:24
 Re: G/MAN 9000 series tractors in reply to G/MAN, 04-06-2007 13:39:14
Thanks for the information. Is their a way I can get in touch with you?
