JD 45 loader hook up
Don Hinsdale
04-05-2007 18:41:21
Am trying to hook up a 45 loader to my JD 50. Previous owner of the loader had two couplings, an inlet and an out let line evidently, one coupling to the fronts of the cylinders, the other to the backs. My powertrol has one solid pin, one open pin, I think I need another open one. Anyone have pictures on how to hook a 45 loader up to a fifty?
Mike M
04-06-2007 05:37:24
 Re: JD 45 loader hook up in reply to Don Hinsdale, 04-05-2007 18:41:21
Not sure what "solid pin and open pin " your refering to ? But if your rockshaft works ? then the way to hook those up ( with a mechanical trip dump )is to remove to 2 pipe plugs on the RH side of the hyd. valve box just ahead of the coupling release lever one is higher than the other and go into the coupler ports. Get some 90* elbows and some pioneer couplings and plumb the loader in there.Hook the hoses up so you move the lever forward to raise and back to lower. You can hook directly into the back with the proper set of coupler plugs ,but then you get pressure when lowering and the loader doesn't work as nice. Those cyls. are only single acting anyhow and the front is just used for an oil reservior.
If you have an optional hyd. dump then it will be different. let us know.
55 50
04-06-2007 13:39:35
 Re: JD 45 loader hook up in reply to Mike M, 04-06-2007 05:37:24
Mike, Are you sure those cylinders are single acting? I have a 45 loader on a 50 tractor with two "Y" hoses connected to the rear hydraulic outlets of the Powr Trol box and one "Y" hose set goes to the cylinder rear connectors and the other "Y" hose set goes to the front cylinder connectors. It definitely has downward pressure and that seems to me to say the cylinders are double acting. Or did JD supply either kind depending on what the customer wanted? I do not have the hydraulic bucket. Ron in MN
Mike M
04-07-2007 04:35:40
 Re: JD 45 loader hook up in reply to 55 50, 04-06-2007 13:39:35
POSITIVE. If you pull one apart there is only a single lip cup packing. If you would try to put much pressure on the lip the opposite way fluid will leak past. The front is only for a reservior on the tractors like a 50,60,70 that don't have enough capacity. The book shows when hooked up to a 520-730 and on 3010,4010 you only run lines to the back and put a breather in the front. And if hooked up like the book shows on a model 50 at the side of the housing you will only have pressure on one set of hoses and this really helps smooth out the lowering of that loader with a heavy load in it. I tried it both ways on my 50 and had alot better results when lifting and lowering heavy loads when hooked up out through the side of the valve housing than through the rear couplers.
55 50
04-07-2007 10:50:55
 Re: JD 45 loader hook up in reply to Mike M, 04-07-2007 04:35:40
Mike, Thanks for setting this straight. I just looked MORE CAREFULLY at my Operator's Manual and it says on page 4: Adjust the tractor hydraulic system for single action cylinder operation (if tractor is equipped with double action valve).
It's amazing how we can get ideas in our brains that we think is right only to find out through more information that we were wrong. Thanks again.
Mike M
04-07-2007 13:27:30
 Re: JD 45 loader hook up in reply to 55 50, 04-07-2007 10:50:55
I think I may of missed that in the book ? I can't remember having readjusted mine ? Or is the setting the same for rockshaft and single acting cyl. ? I don't own it anymore so I can't see where it was set.
55 50
04-07-2007 15:33:15
 Re: JD 45 loader hook up in reply to Mike M, 04-07-2007 13:27:30
The loader manual says to look in the tractor manual for details on the adjustment. My tractor manual only talks of the rockshaft and remote cylinder changes so you are most likely right that single action and rockshaft settings are the same.
