420 \Air Cleaner Mounting?
Henry J
10-30-2003 09:40:10
I am working on this ole beast piece by piece. If and when the time comes, I plan on running it for a while without the sheet metal so the Air Cleaner will have to be mounted back on without the match up to the sheet metal. I was cleaning the air cleaner up today in preparation for paint and noticed that the two extensions fron the spot welded on mounting bracket were bent at a real weird angle. As I look at the mount it would appear to me that the mounting bracket arms (parts that straddle the casting on the block) should come out from the cleaner at relatively the same angle and also will have to be at a distance apart to fit snugly on the mounting point on the engine. I would appreciate it if someone would take a peek at theirs that fits nice and straight through the sheet metal and let me know if my thoughts are correct on the extensions that mount it to the motor? Hmmmm, it would be interesting to know what the air cleaner collided with. I will have to fill some minor dents in the cup that I have knocked back out also. Maybe it was used for driving an occasional fence post or something.
Wayne in Tn.
10-30-2003 10:45:29
 Re: 420 \Air Cleaner Mounting? in reply to Henry J, 10-30-2003 09:40:10
Henry J. Yep those cannisters get banged against lots of things, my guess would be a large percentage of fence posts. The prongs you have bent, are supposed to be straight out from the body, 90 degree angle, if there is such a thing on a round object. They should fit snug over the mount casting, so that if you just loosen the bolt some, it will slip right in or out.
