But size seemed to be relevant when you told me that the wheels were s-o-o-o heavy on a 4840. And didn;t he say the wedges were loose, or did I misinterpret that? And if the tires are loaded, and that makes them too heavy to handle on your equipment, pump it in a couple of drums because it's that easy to remove and easier to put back, as long as you have a few hoses, a pump and some fittings. Then you can handle things with a good sized engine hoist which even an amateur like me has around, and that can even double as a wheel dolly. Whatever the combination of work performed so far has resulted in one guy twisting off a pinion and another guy getting stuck with the job, with no way to get into the nuts on the rim clamps, and asking for advice here. I'd say one of them needs to pass on this work. I guess I don't understand. He asks for ideas, this idea will work if you have the proper equipment, and if you don't have the proper tools then you should take it to someone who does. But since he's the guy it's being taken to, maybe he should pass on this job. No offense meant, really, but if he's done this job before, he didn't even have to ask about alternatives because he already knows, and if he hasn't done this job before, then he's approaching something important, heavy and dangerous with little more than a pair of pliers and a roll of tape.
