ut oh
TEXASJ
04-05-2007 14:49:25
third party image
GOT THIS OFF A WEB SITE. zooks!
jerry dewberry
04-08-2007 12:16:58
 Re: ut oh in reply to TEXASJ, 04-05-2007 14:49:25
uh earl go get a long chain and a big tractor and some help and shovels
buickanddeere
04-06-2007 18:33:16
Once it stops moving, shove the clutch and walk away.
David Snipes
04-06-2007 10:47:10
Dang, I should have put four tires on each side!
Ohio Mike
04-05-2007 20:36:27
Ok, where is that operators manual? Let's see now, wheels spinning, tractor moving downward ?????
JD1830
04-05-2007 19:56:29
Check some of these out!
http://www.iol.ie/~manister/tractortrouble/tractorx7g3.html
Dairy Farmer in WI
04-05-2007 19:20:19
awlright call the backhoe company to dig 'em out! but seriously how do you sink something that deep and why would you even try to move once yer down past the axels!? society these days. the just keep gittin' stupider!
NE IA Dave
04-05-2007 17:19:14
Kind of like the guy that dropped a dine down the hole in the out house. Tossed a twenty dollar bill down beside the dime. No sence going down there for a dime. I guess if you are going to pay for a recovery, might as well get your moneys worth.
No such thing as stuck as long as you have fuel in her, put it in gear, jump out, grab a 12 pack, and wait at the other end of the field.
Gary from Muleshoe
04-05-2007 17:13:13
When I farmed on a dairy in Eastern Ks. We had a 4-150 White. I was working a field that appeared to be completely dry. Even stuck a 12 inch rod in the ground to make sure it was dry enough to work. Anyway I was just tooling along with the 18' disk on behind and the next thing I knew I was buried to the axile housing on all 4 wheels.
Took a 1066 IH, 9000 Ford, and JD dozer to get her out of that hole. Needless to say we let that filed dry a bit longer.
zimmy_10
04-05-2007 20:26:29
 Re: ut oh in reply to Gary from Muleshoe, 04-05-2007 17:13:13
where at in ks. i live in e. ks
CLTX
04-05-2007 15:22:17
Now, that"s stuck, lol. I"ve stuck D"s and R"s before in rice fields, but nothing like that. I wonder how someone managed to bury one like that.
Musta
04-05-2007 15:47:29
 Re: ut oh in reply to CLTX, 04-05-2007 15:22:17
Fergot ta disengage the Stupid Amplifier~
