1943 AR timing hand start
Don R
04-05-2007 09:41:47
HI I have all the sheet metal removed,can't find thetiming mark on the tractor, I have the owners manual,it say's look at FIG 33 for mark but can't see any.Could it be the bent over plate right behind the floywheel.THANKS
John T
04-05-2007 10:16:46
 Re: 1943 AR timing hand start in reply to Don R, 04-05-2007 09:41:47
Yeppers, Look for a raised flat horizontal line/mark.. The Left Hand Impulse (LHI) timing mark on the flywheel ought to be lined up in the 3 o clock position with that flat horizontal mark/line on the tractors side when the left piston is at TDC ifffff f the flywheels on the correct crankshaft spline and the governor gear n cam etc are alllll l in time. Thats when the Mag ought to SNAP ..... .. on BOTH TDC's (power or exhaust) if a direct drive mag like Wico C or X but only on Power TDC if a reduction drive gear mag like Wico AP n some Fairbanks Morse n others.
John T
John T
HaroldIHC
04-05-2007 10:13:02
There is a indicator at the three O clock position of the flywheel right behind the flywheel on a tin cover. coold be coverd with greas. Left hand impuls on the flywheel lines up with it. good luck. ----- ----Harold
JD@Antique Acres
04-05-2007 09:58:38
Don that would be correct
