24 volt 4020
Doug in IL
04-04-2007 17:08:41
My 24 volt 4020 has developed a problem. If you run the headlites, they will dim to almost nothing at lower engine rpms. If I run the engine speed up to 1800 rpm or so, they shine brightly. Problem developed suddenly. Batteries are well charged and starter spins fast. Any ideas where I should be looking?
nickg
04-04-2007 20:01:11
 Re: 24 volt 4020 in reply to Doug in IL, 04-04-2007 17:08:41
may not hurt to have your generator tested too.they only put out around 10 amps at full throttle. Unless it has been switched to a alternator
msb
04-04-2007 17:25:24
Check the small ground wire on the left battery,rear post. It should have a slow blow fuse in the line. Could be the wire has corroded and needs reploacd.
