4240 drawbar support
jd jim a
04-04-2007 16:58:18
Doing the load shaft seals on my 4240. At the front of the drawbar support, there is a pin that holds it to the transmission case. Queston is, what keeps that pin from falling out? I see the roll pin that goes through the support and bushing and comes up against the pin, but is that really all there is to keep that pin from falling out? I realize that pin does fit quite tightly in the holes in the trans case, but my new pin doesn't fit as tight as the old one.
Mike w J
04-04-2007 18:39:29
 Re: 4240 drawbar support in reply to jd jim a, 04-04-2007 16:58:18
That roll pin only holds the bushing in the casting The big pin is pressed in Or drove in .To get it out get a grade 5 3/4 bolt or a peice of shaft and drive it out .If you don't use something about as big as the pin it will only bounce when you hit it .There not to bad most of the time .
Mike w J
04-04-2007 18:47:41
 Re: 4240 drawbar support in reply to Mike w J, 04-04-2007 18:39:29
I didn't let your post sink in before I commented You must have it apart already if it don't seem to fit very tight but is snug. I would put some locktight on it. If you need it out again then you might need a little heat .
