Cracked flywheel
Ben Lanpi
04-04-2007 13:23:26
What causes a flywheel to crack around the hub? anybody have an extra one in Michigan? 44-45 B
ram ranch
04-04-2007 16:19:55
 Re: Cracked flywheel in reply to Ben Lanpi, 04-04-2007 13:23:26
I might have a couple, Have some around that year parting out, in SE MI.
BLinWMi
04-04-2007 13:38:46
where are ya at in Michigan? Flywheels for those are VERY common, as they very seldom went bad. I was at a yard yesterday in Grant and saw a dozen of them.
G/MAN
04-04-2007 13:26:01
Someone not keeping the bolts properly tightened and/or overtightening them in order to get a flywheel to stay tight on worn crank/flywheel splines. I'd look at the crankshaft very carefully while you've got the flywheel off. If the splines are in bad shape, you'll be fighting an uphill battle trying to keep the next flywheel tight.
mjbrown
04-04-2007 15:43:29
 Re: Cracked flywheel in reply to G/MAN, 04-04-2007 13:26:01
The answer to which is a Taper-loc.
G/MAN
04-05-2007 07:28:55
 Re: Cracked flywheel in reply to mjbrown, 04-04-2007 15:43:29
A Taper-Lock would be an option, IF there's one available for that particular tractor. Last I checked, you couldn't get a Taper-Lock for just any two-cylinder. And of course a Taper-Lock is a just a band-aid, treating the symptom - not the disease.
BLinWMi
04-04-2007 17:03:44
I would never spend the money to put a taper loc on a tractor that common. You could buy a good used crank if his is shot and a used flywheel for half of what a taperloc would cost.
